Matth5
Akebono Euro Ceramic brake pads for BMW 335i
Brand new, original box. Ordered from the US.
They were meant to go on my car but I decided to use something else.
Front: Akebono EUR918A
Rear: Akebono EUR1170
These should fit
BMW 3 Series E90/E91/E92/E39 BMW 335i and 335d
They may fit 330i and X1 35i as well.
If you're not sure and don't know how to check, tell me your rego and I'll find out for you.
These are ceramic brake pads, they are designed to dust much less than the standard brake pads. If you like clean wheels these are for you.
From my research the differences compared to the standard BMW pads are that they are not as sharp when you press gently, on the pedal, it's smoother so you need to press a bit more. You may or may not like that depending on your taste, if you're not using BMW pads currently you may not notice that change.
If you like driving aggressively or on a track you might not like that, but it may make regular driving more comfortable.
You can Google "Akebono Euro Ceramic" if you want to do some research before buying. They get mostly good reviews.
$295
Pick up in Botany Downs(my home) or Ellerslie (my work)
I'll charge $20 for shipping as long as there are no special costs associated with your area (eg rural delivery).
