520i jason
E38 nav into e39
Would say one should be able to fit the e38 system into the e39 as they are basically the same set up. Some of the mount brackets might be different and so is  the way it is wired from Japan set to NZ.The radio is shifted to the rear and the screen takes up that space. Other with more knowledge than I will no doubt chip in but try this link and have a read.
https://www.google.co.nz/#q=fitting+nav+to+a+e39+bmw
