cjb
What engine oil for 2006 e90 330i?
Hi,
Just wondering what engine oil options I have?
Quite prepared to spend a few extra dollars for good stuff.
Callum
I would suggest using a branded full synthetic 5w30 meeting the required spec.
We use ELF Evolution 900 FTX 5w30
API:SN/CF,ILSAC:GF5
I would also suggest checking the coolant and only use genuine coolant. 3 X 1.5 litre bottles. There is also a special venting (bleeding) proceedure
Edited by *Glenn*
Not thinking
API:SN/CF,ILSAC:GF5
Thanks Glen (sorry I missed your reply till now).
I ended up using Caltex Edge which supposedly meets the BMW longlife 1 requirement.
I've recently been thinking about the coolant actually so will get that done this weekend - thanks! I have previously used the BMW coolant on my e36 which I got from BM Workshop.. its not the cheapest stuff out there, from memory double what regular coolant costs.
You may need to use a diagnostic machine to vent (bleed) the cooling system. It doesn't always work as seen on UTube. And you will need a 14 volt charger on the battery while this process is carried out.
Strewth! sounds like a job for professionals
Sorry to hijack, this made me curious.
Glenn, How much does this venting cost if done professionally?
Is it time intensive, or 'just' a matter of having the right tools?
We charge $195 to do the job- 1 hr labour & 3 X 1.5 liter bottles of genuine coolant + Gst. This process is only required on vehicles with electronic water pumps. All the others are bled in the normal fashion.
Edited by *Glenn*
Thank you.
