HaNs
FS: E46 Mishimoto Radiator, brand new
https://www.mishimoto.com/bmw-e46-non-m-performance-aluminium-radiator-99-06.html
$690 inc gst
Suitable for a race car or street car
Direct fit for the 1999–2006 BMW E46 323i / 325i / 328i / 330i
Installs in one hour
Reduces coolant temperatures by 19°F (10.5°C) compared to the stock radiator
Fully brazed aluminum core with TIG-welded end tanks
Precision designed CNC-machined quick-disconnect fittings mate perfectly with stock hoses and Mishimoto BMW E46 Non-M Silicone Radiator Hoses
18% increase in coolant surface area
41% increase in air surface area
20% increase in coolant capacity
Fits perfectly with stock electric fan and Mishimoto BMW E46 Non-M Performance Fan Shroud
Fits with the stock or the upcoming Mishimoto aluminum expansion tank
Mishimoto Lifetime Warranty
The Mishimoto Performance Aluminum Radiator for BMW E46 non-M vehicles is designed and engineered to reduce coolant temperatures by 19°F (10.5°C), and to protect your car from overheating during aggressive driving or hot lapping sessions. It is the ideal upgrade for your 3-series, and will outlast the weak stock plastic radiators. The Mishimoto BMW E46 radiator features a large two-row core, 100% brazed aluminum construction, and polished end tanks, resulting in greatly improved cooling efficiency for your engine. The engineers at Mishimoto designed this E46 radiator to feature a 20% increase in coolant capacity over the stock radiator. The Mishimoto E46 radiator also improves coolant surface are by 18% and air surface area by 41%. This aluminum radiator is an ideal upgrade to keep your E46 running cool! This innovative radiator design features CNC inlets and outlets that work perfectly with your stock plastic quick-disconnect and Mishimoto E46 Non-M Radiator Hoses! The Mishimoto BMW E46 radiator comes in two separate versions for manual and automatic transmissions; with the automatic transmission model featuring an auxiliary inlet port for the stock automatic transmission cooler connection. Every Mishimoto aluminum radiator is a direct-fit making installation effortless. Like all Mishimoto BMW performance parts, this radiator includes the Mishimoto Lifetime Warranty, ensuring superb product quality and craftsmanship.
