chiz
Distributor for E21, or 2002.
After altering my dizzy to take electronic  ignition and ECU-which has now got an unrepairable fault!! am unable to go back to the standard, can't find the bits I removed and mech adv solidly epoxied solid. Anyone got a spare lying about, I think its a JFU4. For a '73 2002,  M10 from an E21.
Paul Chisholm , [email protected]    0274501711
I might have a spare, will have a look tomorrow.
Into my 2002 Brent, which has the M10 from an E21,its Paul here, sent you a tx couple days ago asking if you had any spares !!
sh*t did i reply?? i dont recall seeing a text. sh*t will look when i get home.
i only have m20 stuff any way.
was asking as there is a e21owners registry being created at the moment.
You may have me confused with Brent from BM world.
Im brent from Vapour Blasting NZ
I have one, do you need the drive housing as well or just distributor?
Thanks Andrew, I need the actual drive housing and insides, in other words the complete except for dizzy cap.  How much and where could I collect ? Tx 0274501711 Paul
Hi Brent, no I was thinking of Brent Parker of GreenStuff, racing a M20 e21 in bright green. Sounds like the E21 world is full of Brents !!
All good. Brent and i chat often.
Hey Andrew, sent you a couple of messages, do you still want to sell the distributor ?
I've had my '75 2002 converted to electronic ignition and have the bits that used to sit in the distributor, also the condenser. Not sure if this is what you are looking for but you're welcome to them if it helps.
