dirty36 0 Report post Posted June 4, 2017 Can this flange be taken off and put into a different axle? I've got the wrong axle so it won't bolt up to my diff and I've been trying to get my original axle out but it's rusted in. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 4, 2017 there are medium case diff flanges 323i 325i 328i , and small case 318i 316i 318ti 320i 318is etc medium case type axles are larger diameter and have bigger flanges and splines etc , also factory manual medium size axles are fatter in the middle of the shafts . if you cant get the axle out of the rear arm , just change the whole arm/axle unit some times you need the correct tools , like a press or hub puller /axle pusher etc to get them to come out also heat and soaking in lube etc can help have all options in stock and can freight Quote Share this post Link to post Share on other sites
dirty36 0 Report post Posted June 4, 2017 1 minute ago, BM WORLD said: there are medium case diff flanges 323i 325i 328i , and small case 318i 316i 318ti 320i 318is etc medium case type axles are larger diameter and have bigger flanges and splines etc , also factory manual medium size axles are fatter in the middle of the shafts . if you cant get the axle out of the rear arm , just change the whole arm/axle unit some times you need the correct tools , like a press or hub puller /axle pusher etc to get them to come out also heat and soaking in lube etc can help have all options in stock and can freight Are the medium case axles also bigger on the wheel bearing side too? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 4, 2017 9 minutes ago, dirty36 said: Are the medium case axles also bigger on the wheel bearing side too? no same bearing and hub flange etc Quote Share this post Link to post Share on other sites
