Zzz
E30 Parts - Manual/M50 Conversion
After the following:
E30 Clutch Resevoir or Cap
E30 M20 Clutch (Depends on price)
E36 Engine Mounting Arms
Brake Booster for M50 Swap (If anyone happens to have one lying around)
M50B25TU Parts - Oil Sump Gasket, Rocker Cover Gasket
i have a brake booster off a e21 that i will swap you for the trailing arms off your e34.
i have engine arms, also have stainless m52 manifolds if you need as well
