Michael.
FS; 2003 318ti 107kms
NZ new 318ti, second owner since 2006.
Good over all condition inside and out, drives extremely well having done only 107kms.
Chain driven, so no cambelt to replace.
Includes a comprehensive service history
Some service items done in the last few years include:
> Rocker cover gasket
> Crank case vent hose
> Crank shaft sensor
> Oil filter housing seals
> Vanos solenoid O-rings
> Top Radiator hose
> Throttle valve replaced
> Engine sump gasket, dip stick o rings
> Front lower control arm bushings replaced
> Aircon pump clutch coil and valve, drier replaced, A/C regassed (Sept 2016)
> 1x ignition coil replaced (Oct 2016)
> Expansion tank replaced (June 2017)
> Cyl heat to thermostat hose (June 2017)
Viewing available in Ellerslie, Auckland.
$5000
P1200763.thumb.JPG.5437dba6ea466994e93dfa79ef0aa949.JPGP1200762.thumb.JPG.df1345654b43499f4cd91cb0685b3efe.JPGP1200765.thumb.JPG.5be6e765153ce228425a3685e98c44d1.JPGP1200766.thumb.JPG.11dea155741940a33a6895be5ac5f270.JPGP1200771.thumb.JPG.19f906ecf945de58cb280177c1c63c2b.JPGP1200775.thumb.JPG.af38eb7e6124337103bc71c115a7cd1c.JPG
Edited by Michael.
