Ash 0 Report post Posted August 23, 2017 hi guys i have a 2007 e90 320i, no idrive i changed the led angel eye bulbs to led and they had been going good for a few months. then the passenger side angel eye started flickering, over time it completely stopped working. its putting out the code cc-id 13 which is a fault which the passenger angel i believe. changing the bulbs doesnt solve the issue. so i am led to believe that it is an issue regarding the frm module. from what ive read online, when the frm module detects a short circuit within the system, after the ignition has been cycled 50 times, it will disable that circuit to prevent damage. normally the frm module would need to be replaced in this instance, but i have seen online that you can solve frm short circuit issues with some coding. people use the toolset32 program to reset the short circuit count from 50 back to zero to tell the frm to turn on the circuit again. is there anyone in auckland or hamilton that is able to help me. so annoying driving with one angel eye, and the bulb warning never goes away. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted August 25, 2017 try this see the seventh post talks about a relay https://www.bimmerforums.com/forum/showthread.php?1848993-LED-angel-eyes-flickering Quote Share this post Link to post Share on other sites
Zee 0 Report post Posted September 19, 2017 try other bulbs that are error free. https://www.trademe.co.nz/Browse/Listing.aspx?id=1421544291 Also try getting a carly for bmw coding kit. you can find info about carly for bmw on youtube. hope this helps Quote Share this post Link to post Share on other sites
