dkonsta1 109 Report post Posted November 28, 2017 My Mrs used the car today after a long time sitting. She started the engine normally backed of the garage started driving and within the first 100 metres the car could not accelerate. She pulled over immediately and the engine stalled. Now the car won' start again although the engine cranks but it will not fire. I am 99% sure I cannot hear the fuel pump going when I turn the ignition switch on. I am heading away for a couple of days will get back on to it Saturday morning. I suspect fuel pump relay or pump itself or other worst issues (cam shaft sensor , etc.) Any thoughts? Cheers. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 28, 2017 They have a pressure test valve on the fuel rail, standard Schrader type Quote Share this post Link to post Share on other sites
dkonsta1 109 Report post Posted November 28, 2017 Yes I was planning to check. I Should get pressure with the ignition in position 2 Correct?. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 28, 2017 Correct. Being a returnless rail the regulator is in the filter Quote Share this post Link to post Share on other sites
Kiwi_BMW 90 Report post Posted December 1, 2017 If you are looking for a new fuel pump let me know I've got a new one sitting at work Quote Share this post Link to post Share on other sites
