adz 50 Report post Posted November 30, 2017 Hey team, Does anyone know the part number for a valve cover gasket, metal cover, out of a E36 328i. All the ones I seem to find are for the plastic covers. Cheers, Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted November 30, 2017 The bit you can see inlaid in this picture? If so I'm not sure that it's available as a separate part... Quote Share this post Link to post Share on other sites
adz 50 Report post Posted November 30, 2017 No, its the rubber gasket between the head and the valve cover. Not the coil cover?? I got a one but its for the plastic valve cover, mine is aluminum. Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted November 30, 2017 Just now, adz said: No, its the rubber gasket between the head and the valve cover. Not the coil cover?? I got a one but its for the plastic valve cover, mine is aluminum. This should be the right one, 11120034107 ......also its not aluminum its magnesium believe it or not! Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted November 30, 2017 Cylinder head cover gaskets? If so, which cylinder head cover is made of plastic??? Quote Share this post Link to post Share on other sites
adz 50 Report post Posted November 30, 2017 (edited) Magnesium, hmm interesting. Some of the M52B28 covers are plastic, Edited November 30, 2017 by adz Quote Share this post Link to post Share on other sites
adz 50 Report post Posted November 30, 2017 9 minutes ago, BatMansWilly said: This should be the right one, 11120034107 ......also its not aluminum its magnesium believe it or not! Awesome, thanks for that. Quote Share this post Link to post Share on other sites
