gjm 3300 Report post Posted December 28, 2017 Before I head out and spend the GDP of a small South American country on a new battery for Miss M's 318Ti, does anyone have a good one they're not using? None of the usual battery suppliers are open in these twilight days of 2017, leaving Repco, SCA etc as possibly the only option. (It'd be nice if their fabled "60% off stocktake sale!" included batteries... ) Specs for suitable solutions seem to vary very slightly, depending on where you look, but a DIN55L or DIN66L with 500-600CCA should be fine. Fitted was a MF55-spec battery: LxWxH: 240x175x175mm (there's room for a little something taller, but length and width are important) 12V / 54Ah DIN 270A EN 450A SAE 500A Bosch Type 'A' terminal position: Here's hoping someone can help! Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 29, 2017 OK - it was always a long shot. Went to Repco where they wanted $279 for a 530CCA battery of appropriate dimensions, with a 3Y warranty. Same thing from Supercheap - $199. There is a difference... Which I didn't find until I fitted it. The clamping flange on the end of the battery is almost an inch up the side, unlike the original which is on the base, so I had to fabricate a clamp plate. Quote Share this post Link to post Share on other sites
