Crossbow
SOLD M43 single mass flywheel
I have a single mass from a 1996 m43 316i bought as part of a conversion package but decided to go a different route. Has pressure plate and clutch on it, but the person I bought it off spilt engine assembly lube on it. Haven't had it apart but you'll definitely need a new clutch. All bolts there. Will fit m50 and m5x if you want a cheap single mass conversion but the clutch size is only 215mm clutch size so take that with a grain of salt.
Its on Trademe here: https://www.trademe.co.nz/Browse/Listing.aspx?id=1521281950
Price $100
Edited by Crossbow
