Docile 64 Report post Posted February 23, 2018 Hey Guys, 740i M60 The car just wouldn't start last night after parking it at the supermarket and I had to get it towed home. Car cranks but doesn't turn over. checked crankshaft sensor and it has 540 ohms. I plugged in my diagnostics, but it would not connect to the ECU or transmission. but it does connect to airbag?? I plugged in my diagnostic to the car last week and it showed no error but now it can't connect. Usually when I have the key on position two, you can hear the electronics in the engine bay initialise itself to start. like the idle control valve would hum and the cruise control cable would do its self check. but right now nothing. where is the fuse for the ECU? anything else i might check / missed? recent work on the car: new ignition barrel 1 month ago. window regulator its looking like the ecu had packed it :'( thanks guys Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted February 23, 2018 What condition is your battery in? 1 Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted February 23, 2018 battery is in tip to knick..but right now im charging out of the car. yes. it cranks but no start :(. AA came over and sprayed 'start ya bastard' on the intake last night and wanted to start. ill buy a can and see if it wants to start tomorrow. if it does its got ignition, just no fuel? its just baffling that dme and trans cant be connected to anymore? where would i start to check power to DME? i've check all the fuses and all are good (glovebox, driver side and trunk.) Quote Share this post Link to post Share on other sites
drtimwright 104 Report post Posted February 27, 2018 Personally, I'd follow the diagnostic steps in this video (I know, it's not a BMW, but the basics are the same). Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted March 1, 2018 cheers guys, found it!!. main power relay in the ECU box. the white one was dead. I managed to find a replacement a voila. it started first thing. 3 Quote Share this post Link to post Share on other sites
