Funkyflynz 151 Report post Posted February 28, 2018 Guys, Planning to take the 2.8 and manual ZF trans out of an E36 sedan and drop it into a E36 coupe. The question I have is does the pedal box, clutch master cylinder, clutch lines, shifter etc from the sedan bolt straight into the coupe shell? FYI I have two coupes I can use, one is a 328 auto, the other is a 318 auto. not sure if it makes a difference when doing a swap like this? Appreciate any help. Lee Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 2, 2018 Haven't done a conversion in an E36 but i would say those parts would be interchangable between shells - as they are in the E30, Main structures tend to be pretty generic in BMW's. Pedal box may be as in E30 where you can simply swap the pedals & longer pivot bolt into the existing box. Quote Share this post Link to post Share on other sites
