Ahmedsinc 414 Report post Posted March 2, 2018 As above, shedding parts I'll probably never get around to using. Muffler is in 8/10 condition, had two small rust patches that were cut out and replaced. Sounded far nicer than the equivalent Remus system imo, well mannered burble up to 5k rpm then proper raspy at WOT. Rare as (insert cliche here), only E36 big 6 muffler I've found that isn't Remus / AC Schnitzer / Borla etc... $600 Also have an M20B25 SM flywheel and starter, again will probably never pull finger and use this. Surface could do with a skim if you were super keen but I was intending to use it as is one I degreased it. No hot spots on friction surface, I am of the understanding it has been machined to suit an M50 but thats for you to confirm. $250 Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted March 4, 2018 Could be interested in the exhaust for the m3, but what were the size of the incoming pipes Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted March 4, 2018 Both sold. Thanks for all the interest Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted March 4, 2018 9 hours ago, euroriffic said: Could be interested in the exhaust for the m3, but what were the size of the incoming pipes 50mm in, 75mm out so not really the best option for the S50 Quote Share this post Link to post Share on other sites
