Ahmedsinc
E36 328-325i Supersprint muffler & M20 SM flywheel
As above, shedding parts I'll probably never get around to using. Muffler is in 8/10 condition, had two small rust patches that were cut out and replaced. Sounded far nicer than the equivalent Remus system imo, well mannered burble up to 5k rpm then proper raspy at WOT. Rare as (insert cliche here), only E36 big 6 muffler I've found that isn't Remus / AC Schnitzer / Borla etc...
$600
Also have an M20B25 SM flywheel and starter, again will probably never pull finger and use this. Surface could do with a skim if you were super keen but I was intending to use it as is one I degreased it. No hot spots on friction surface, I am of the understanding it has been machined to suit an M50 but thats for you to confirm.
$250
Could be interested in the exhaust for the m3, but what were the size of the incoming pipes
50mm in, 75mm out so not really the best option for the S50
