Simca 49 Report post Posted March 28, 2018 Hey guys. My radiator is broken and I'm trying to source a replacement but apparently the pfl 320i rad is pretty uncommon and hard to find. If I want to swap to a facelift radiator what will I need? Or alternatively could I fit a 325i pfl radiator with the stock hoses and setup or will it require a different set up? Cheers Quote Share this post Link to post Share on other sites
Palazzo 491 Report post Posted March 28, 2018 From memory when we had both they were quite different, I don’t think you’d get them to work, but could be wrong, it was a while ago.. I don’t believe one radiator is harder to find than the other either....... Quote Share this post Link to post Share on other sites
