Cev 0 Report post Posted May 20, 2018 Gidday folks, I’m quite new to the forum however ran out of places to search for a few items needed to complete my manual conversion on my recently purchased 1989 320i E30. It’s running in M20B20 motor and 4HP22 auto trans-which I am converting to manual using a G245 box which I purchased recently. I’m after a driveshaft that will be compatible without any modification, but I am open to ideas which may require modification in order to get the driveshaft fitted. Located Wellington Cash ready & waiting Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted May 20, 2018 I could be wrong, but you might struggle to find one that’s a bolt in affair. As 245s were only found in one model of e30 (I suspect you have an e21 box). http://www.e30zone.net/e30zonewiki/index.php/Drivetrain#Manual You may have to get a driveshaft modified to fit. However if it’s the same length as a 240 or 260 than there will be driveshafts out there. I’ve got a 260 (can’t recall the exact version) if you’d like me to measure it. Quote Share this post Link to post Share on other sites
Cev 0 Report post Posted May 20, 2018 3 hours ago, eliongater said: I could be wrong, but you might struggle to find one that’s a bolt in affair. As 245s were only found in one model of e30 (I suspect you have an e21 box). http://www.e30zone.net/e30zonewiki/index.php/Drivetrain#Manual You may have to get a driveshaft modified to fit. However if it’s the same length as a 240 or 260 than there will be driveshafts out there. I’ve got a 260 (can’t recall the exact version) if you’d like me to measure it. Will the shaft fit both G240 and G260? just after easiest manual route. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted May 21, 2018 There’s a different driveshaft for each gearbox (on my earlier link it also talks about driveshafts). Quote Share this post Link to post Share on other sites
