Cloudxiii 0 Report post Posted July 6, 2018 (edited) My car has audio controls on the dash and a CD unit and CD Stacker underneath. My question is, would it be possible to connect a single din head unit so that it would work under the CD source? The reason I want to do this is because I have a head unit that I can connect and control my iPod to. I don’t listen to Cd’s anymore so I don’t see the point in having a CD player and a CD stacker. Any advice would be appreciated. Thanks. Edited July 6, 2018 by Cloudxiii Added photo Quote Share this post Link to post Share on other sites
kwhelan 241 Report post Posted July 6, 2018 those stereos have aux in, you can connect a bluetooth receiver and stream audio in thru the amp and speakers, have to be controlled by the iPod tho. Quote Share this post Link to post Share on other sites
Cloudxiii 0 Report post Posted July 7, 2018 11 hours ago, kwhelan said: those stereos have aux in, you can connect a bluetooth receiver and stream audio in thru the amp and speakers, have to be controlled by the iPod tho. The Aux doesn’t work and I can’t figure out why. Also, the whole point of trying to install my head unit in place of the CD player and CD stacker is so I can control my iPod through the head unit. Thank you for your suggestion though. Quote Share this post Link to post Share on other sites
Cloudxiii 0 Report post Posted January 23, 2019 The below pics are of a wiring diagram with the wiring loom belonging to the diagram and a ordinary aftermarket wiring loom. I need to join the 2 together but not sure which wires connect to each other. Can anyone please help. Quote Share this post Link to post Share on other sites
Cloudxiii 0 Report post Posted January 23, 2019 It is the left hand column of the wiring diagram which should be used as a reference. Quote Share this post Link to post Share on other sites
