redmdamson
Heater Issues
Hey folks,
newbie here and definitely don’t know jack sh*t about anything BUT I do know that the fact that the heat isn’t  consistently working unless the RPMs are up it’s an issue.
Here are the factors: coolant leaks a lot, car doesn’t warm up very quick, when driving roughly under 30 the heat completely stops until I go back up to 60. I have the heat up to 90 F. I also let the car warm up for 5-10 minutes.
Please help me as I am a broke woman who’s second rig needs a new rear diff.
Fix the coolant leaks. Check thermostat and water pump are in working condition. Make sure it is bled of air properly.
If you still have problems after that then you cam look at heater control solenoids etc. But sounds like you have other problems to fix first
