antman 0 Report post Posted December 11, 2018 Hi all, Does anyone know anywhere in Auckland that can diagnose if my ABS Module is at fault? I have had it scanned, which came up with a wheel speed sensor, replaced that sensor but still same issue. I've had some issues using Multimeter to test sensors from connector. Would be good to have someone that can check module directly before I look at paying to have module repaired ($450) or find a new replacement overseas and programmed for car. Ta Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 13, 2018 You should scan it with live data to see what is happening. Internal module faults can cause all kinds of rogue fault codes. I would bet the module at fault. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted December 14, 2018 Powerstop Engineering in Tauranga is the place to use. Quote Share this post Link to post Share on other sites
