antman
E39 ABS Module Scanning
Hi all,
Does anyone know anywhere in Auckland that can diagnose if my ABS Module is at fault? I have had it scanned, which came up with a wheel speed sensor, replaced that sensor but still same issue. I've had some issues using Multimeter to test sensors from connector.
Would be good to have someone that can check module directly before I look at paying to have module repaired ($450) or find a new replacement overseas and programmed for car.
Ta
You should scan it with live data to see what is happening. Internal module faults can cause all kinds of rogue fault codes.
I would bet the module at fault.
