kiwi6539 3 Report post Posted February 5, 2019 Hey all. 89 e34 530i m30 b30 Hello can anyone tell me if my relay is in the front fuse boxes either side engine bay or under the rear seat? And number/details for relay part to check correct. My Horn just stopped working. Fuse good if not relay anyone had the same problem. Cheers Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted February 5, 2019 Its in the engine bay Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 7, 2019 Cheers. No luck is it common with age air horns are dead? I started to attempt to remove grill bits to get to them check connections clean etc but didn't get far. I knew I'd break something not knowing where clips process order etc. Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted February 7, 2019 Would think its more likely the connection but its possible it just died with these cars being old. There is hole above the indicator lens in which you stick a long flat screw driver down to release the corners. I can email a copy of the E34 Bentley manual which give you a step by step. Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 8, 2019 Thanks that would be great Haynes manual doesn't mention those holes to release. And by connection you mean to the horns?.I 'm wrecking a 89 525 auto at the moment for a few spare parts so have some to try to eliminate horn when get to them.. My have some parts sell after done Cheers Quote Share this post Link to post Share on other sites
Eagle 1776 Report post Posted February 8, 2019 Yeah to the horns which would mainly be all the connections, grounds etc on and behind the steering wheel. PM me your email and ill send it thru. Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 10, 2019 Hi My email [email protected] I found another video do you push clips down and have to use some force? Cheers Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 11, 2019 Hi Eagle Ive got it going I went back through from steering wheel. Checked cleaned again and it's going. Thanks for all the advice. On to heater panel light now. Will make another post Quote Share this post Link to post Share on other sites
