kiwi6539 3 Report post Posted February 16, 2019 Hello all. This is mainly for the E34 owners out there. Sorry if wrong forum I wasn't sure which forum to post in. I'm wrecking a E34 89 525 Auto mainly to save a few parts for mine which is a daily. Can anyone suggest parts worth saving like switches windrow motors etc for my car for breakage and worst case in the future. And stuff worth just getting rid of or selling. Plan to post parts after its in bits if worth selling them. Sorry long question Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted February 16, 2019 General E34 stuff isnt worth much and doesn't normally sell. BMW generally used durable electronic parts those days and you can also repair most things without replacing. Window regs, motors and switches rarely fail themselves but guess easily enough to store. Doors and panels are always good if you got the space. All exterior lights, heater valve, fuel pump\sender, instrument cluster, LKM and CCM module (if its digital), door cards maybe is all i can think of Guessing its just got the basic manual vent control HVAC system? Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 16, 2019 (edited) 12 hours ago, Eagle said: General E34 stuff isnt worth much and doesn't normally sell. BMW generally used durable electronic parts those days and you can also repair most things without replacing. Window regs, motors and switches rarely fail themselves but guess easily enough to store. Doors and panels are always good if you got the space. All exterior lights, heater valve, fuel pump\sender, instrument cluster, LKM and CCM module (if its digital), door cards maybe is all i can think of Guessing its just got the basic manual vent control HVAC system? Hey yeah manual vents etc has air con in it and mine doesn't but not going there. Tow bar, auto box running gear replica schnitzer rear wing. Yeah will just save motors actuators doors glass etc. Will most likely Scrap most of it hurts cutting one up to pieces Edited February 16, 2019 by kiwi6539 Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 16, 2019 Can anyone tell me what from front end rear end to save steering arms, sways bars that you can't replace bushings or reuse so just throw away. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted February 16, 2019 All that stuff is still available and you probably would fit new components your current one worn. Center tie rod, pitman arm and steering box would be the only things possibly worth keeping on the front. Those early front strut bearing assemblies are another thing to keep as they are expensive or even NLA for OEM and expensive for Meyle aftermarket ones. Probably easier just keep the whole strut assembly with the bearing etc. Wiper linkage\motor maybe worth keeping also if you can be bothered removing it. Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted February 17, 2019 Cheers Thanks I will. I have enough space to store a bit. Gearbox and converter worth selling engine is gone m20 b25 but think he's decided not to swap to e30. Might be for sale In future if know anyone. Wondering on diff axles etc and what's worth selling or taking straight to tip recycle etc Quote Share this post Link to post Share on other sites
emandru 17 Report post Posted February 17, 2019 +1 on pretty much everything stated above. However, if you dont want that wiper assembly I might be keen on it... Quote Share this post Link to post Share on other sites
