Paragon 14 Report post Posted February 23, 2019 (edited) Loads of M20 stuff : Inlet manifold 2.0 still with injectors and rail $40 Inlet manifold 2.5 painted black $40 Inlet manifold 2.5 vapour blasted$80 Exhaust manifold 2.5, 3 stud $50 Rocker covers and other covers vapour blasted Camshafts, all good with no obvious wear, not sure if they are 2.0 or 2.5. Apparently they vary so they will need to be checked $60 crank, and other pulleys Flex plate for auto, early motronic with the trigger on it $50 Crank 2.7 H81 $100 Crank 2.5 H75 $100 Bearings, new standard size, fits many engines, M20s amongst them. rod CR6640CP mains MB7039AM Part number CR6640CP (STD SIZE) Mainly used for BMW 6 cylinder M20 M50 M52 M54 2.0-3.0 petrol engines and M21 M51 M57 2.4-3.0 diesel engines. Size: STD Position: connecting rod bearings Pairs/Quantity: 6 (complete set for one engine) Crankshaft diameter: 44.991/44.973mm $150 Rods, 2 sets, 2.5 135mm. One set maybe M50 rather than M20, a bit lighter. $100 Valves and valve springs 2.0 and 2.5 $5 and $2 each price as required, make an offer for multiple parts. Location south auckland. Edited February 23, 2019 by Paragon prices 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted February 23, 2019 Please put prices against the items you have listed, as per forum rules, thanks. Quote Share this post Link to post Share on other sites
malus139 5 Report post Posted March 9, 2019 Pmd Quote Share this post Link to post Share on other sites
