Eagle 1784 Report post Posted March 16, 2019 (edited) All in working order pulled from a M52 engined car. Good M50 SMF conversion etc but would recommend a taller release bearing (E21 323i) as clutch bite point was quite low. M20 228mm single mass flywheel, weight is approx 7.1kg Luk clutch kit with good life, done approx 10,000km according to PO. M20 starter motor Have bolts and spacer also $350? Edited March 16, 2019 by Eagle Quote Share this post Link to post Share on other sites
