Ahmedsinc 414 Report post Posted August 26, 2019 (edited) E46 330i Motorsport sedan stuff for sale. M50B30 stroker kit. B30 rotating assembly & injectors with M50B25 long block & B30 cams, trays & lifters. M50B25 injectors & fuels rail. Can also supply with a 413 DME & M50 + M54 harness. Can use the B30 intake but will require a little modification to suit the B25 head, intake free if wanted. Probably 85% complete, needs accessories & intake manifold and an overhauled Vanos unit as i burgled some bits to fix mine. Looking for $900 together. Also have an adapter plate to run the B25 throttle body on the B30 intake, will supply with TB for an extra $50. Style 68 wheels, 2 each 7.5" & 8.5", some curbing, tyres fcked from poor alignment $200 Lower control arms with bushings $120 / pr 3.34 open diff $100 Headlights & clear tail light set including clear side repeaters & indicator $200 for the lot Pre Facelift Motorsport bumpers & flat side skirts including rear PDC sensors, front comes with foglights $150 Front guards $40, passenger doors (window regs dead) $50 bonnet $40, Titansilver Metallic Happy to send through photos on request, also happy to set up trademe auctions for buyers that can't collect. Franklin area for pickup. Chur Edited August 29, 2019 by Ahmedsinc moar photo Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted August 28, 2019 You need to post pictures of all the parts listed please, as per the For Sale forum rules. Quote Share this post Link to post Share on other sites
