speedyg
The good oil?
I am planning to do the diff and gearbox oil this weekend. I have read that Redline is pretty good.
What grade do I go for and does anyone know who sells it in Christchurch?
Any other oils recommended?
The car is a 1989 E30 325i 5 speed and open diff.
Thanks
Redline MTL for both the diff and g/box - ftw
E: You'll need a bottle for each
Edited by Carl
Found Redline oil at BNT Automotive on Montreal St.
I have done the gearbox but when I went to do the diff I found it has a different size Allen head plug to the gbox.
Does anyone know off the top of their head what size it is as I forgot to measure it and want to get one today? I'm guessing around 15mm.
Just get a set if you can afford it...especially since you must have the massive g/box key.
