nz320i
Gearbox seal
is there a seal between the gearbox and the engine? i have a small leak where he two meet and wonder if its bad or have other people got the same prob? not a huge leak
cheers!!
sure is..rear main crankshaft seal...$75 ish..and need to take the box off to get to it. fun! and make sure you put in on right the first time..saves having to take the box off again a week later
not to mention big puddles of oil everywhere.
oh yup, 4 axle stands do the job then?! its all i have!! aslo can i buy the torx ( i think ) bits for a rachett at repco? as the stupid box has to have different bolts to everything else <_<
only need 2 axles stands! 4 makes it easier..you can buy a set of torx females from repco...$60 i think. although i got mine for $40
