WarNox
Steering wheel "skips"
Whenever I turn the steering wheel slightly, either left or right, when the car is running I can feel something skip. As if there is a bump and something jumps over it suddenly! Anyone have any idea what this is?
Thnx in advance...
Wheel alignment, uneven tyre wear or something in the suspension or steering worn/loose. Tkae it in to somewhere like Midas for one of those free vehicle checks. Unless someone actually drives your car to see what exactly is happeneing then has a look underneath those symptoms are pretty tricky to diagnose.
ok i took your advice and took the car to midas! they said its one of my ball joints, i do not belive them because they were both replaced and the problem continued after it! now, they also said something is wrong with my steering rack because the power steering fluid is dirty! How much do you think this would cost to replace or fix ? and a good place to do it?
