CoxyNZ 2 Report post Posted December 13, 2019 I have a 88 E30 with a 2.7 stroker m20 motor and need a new distributor cap and rotor. Where is the best place to buy one for cost/quality in NZ? Also are all m20 cap and rotors the same? Thanks Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3022 Report post Posted December 17, 2019 There are two versions of the M20 dizzy, early L-Jetronic which has dizzy out the side of the block and the later Motronic where the dizzy is off the front of the camshaft. Which version was your 2.7 stroker built from? I would imagine it’s the later Motronic version. Unfortunately the caps for these are always expensive. Best bet would probably be to bring it in from USA is quite small and light. Quote Share this post Link to post Share on other sites
