Gus 5 Report post Posted April 5, 2006 how does the mtech 2 kit attach (genuine) more specifically, the side panels? one of mine is a little askew, i think it just needs to be popped back on. if anyone could describe it in detail, or even better with pics, it would be much appreciated. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 5, 2006 Arent those side panels just glued on with the same stuff they hold the '325i' badge on with? And they are hooked onto the same clips that the normal door trims are hooked onto? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 5, 2006 I believe the side skirts clip on. Thereare holes drilled with plastic grommets that little nipple-type clips pop into. So, you may have to create these on a non- ///m 325. Or use some other method of attaching them. Quote Share this post Link to post Share on other sites
smithy 0 Report post Posted April 13, 2006 how does the mtech 2 kit attach (genuine) more specifically, the side panels? one of mine is a little askew, i think it just needs to be popped back on. if anyone could describe it in detail, or even better with pics, it would be much appreciated. there are 4 holes 3 are for the clips and 1 is for nut if u have no clips do what i did and use the clips off the inteara door cards but firstly try pushing it back on Quote Share this post Link to post Share on other sites
M3 Cab 0 Report post Posted April 13, 2006 Putting mine back together this Saturday at Bavarian if ya wanna have a look. Quote Share this post Link to post Share on other sites
