LsBeema 474 Report post Posted January 17, 2020 Easier to leave the stabaliser in place, disconnect the steering shaft, keep the lines bolted, loosen front arm at hub side and center one at the crossmember, then get to sideshafts and diff. 1 Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 17, 2020 (edited) And dont be a wally and forget to loosen & shift the power steering pump ay. Edited January 17, 2020 by LsBeema 1 Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 17, 2020 https://youtu.be/ljDnDKw2iHY 1 Quote Share this post Link to post Share on other sites
Statek 87 Report post Posted January 17, 2020 Great info! How many hours of labour is it? I'm not looking forward to doing this on the ground in my garage... Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 20, 2020 (edited) Nah its a "piece of urine mate"...well in a worshop that is?? Like around 4 hrs to remove brru. ...10-12 for the whole job ResTecp for doing it on the floor though??. Let me know if you need any tools man. Put some brackets to hold the rack up while you replacing the gasket Cable tie the stabiliser bar up before removing rack then remove it after before removing sump....you'll know. I put a thicker film of silicon on the metal and a lick on the rubber cos the surface area is so small. Also all that weight and inertia of the diff...not such a great design in my opinion to only be held by +-30 m6 bolts with no even dowel pins. I chuck some locktite on all subframe mounting bolts...just to help me sleep more peaceful at night Hope you have some slim az forearms to get that steering shaft in....you have to pull it down as it collapses upwards...and dont bolt it to the frame. ...push the shaft in first.. Uhh..what else...oh yea....cable tie the rear subframe covers backwards so its easier to remove and fit it...youll know. Schweet. ...oh yea..diff seals and orings too Edited January 20, 2020 by LsBeema 1 Quote Share this post Link to post Share on other sites
Statek 87 Report post Posted January 20, 2020 16 hours ago, LsBeema said: Like around 4 hrs to remove brru. ...10-12 for the whole job ResTecp for doing it on the floor though??. Let me know if you need any tools man. ...and with that I might deal with it weeping for a little while longer ? Thanks for the offer dude, I'll be in touch if I get brave enough! Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 20, 2020 New c.v nuts too homs Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 20, 2020 What!!! All that info and you're being a pansy???..haha..nah. tough one on the ground man. 1 Quote Share this post Link to post Share on other sites
LsBeema 474 Report post Posted January 20, 2020 420nm on hub nut...if you man-up? 150 on wheels Quote Share this post Link to post Share on other sites
