LemonHunter 583 Report post Posted January 21, 2020 https://www.trademe.co.nz/2501046767 $550 for bimmersporters Description 1 x CAMSHAFT LOCATING FIXTURE: Aligns and holds the camshaft in position when assembling cylinder head and replacing timing chain. Engines: M42, M44, M50, M52, M52TU, M54, M56, S50US, S52US. 1 x TOP DEAD CENTER PIN: Use to lock the flywheel at Top Dead Center when removing or replacing the camshafts or VANOS assemblies. Engines: M42, M43, M44, M50, M52, M52TU, M54, M56, M60, M62, M70, M73, S50B30, S50B32, S54, S62. 1 x VANOS TURNING WRENCH: Use to adjust VANOS position on single VANOS engines when removing or installing. Engines: M50, M52, S50US, S52US Features & details Kit includes everything you need for locking camshaft in TDC position when checking/adjusting camshaft timing, replacing inlet camshaft or timing chain on BMW M54/M52/M50 Ready to use. Strong and durable. For professional use. Quote Share this post Link to post Share on other sites
