Paragon 14 Report post Posted March 6, 2020 Various M20 engine parts, crankshaft 2.5 H75 GGG700 good journals $100 885 head, vapour blasted, hardness tested, pressure tested, straight, with valves / springs / collets/ rockers $900 Short block rotating assembly 2.5, taken out due to smoking on gear changes. $250. Good bores. Camshafts, 2.0 and 2.5, no wear $30 each Rods 135mm, not sure of origin, may be M50 engine $60 set Rods, 135mm not sure of origin, probably 2.0 litre $60 set Rocker cover $30 Bearings main standard - check part number King MB7039AM $100 Bearings big ends standard - check part number King CR6640CP $80 fuel rail, 325, $20 engine mounts vapour blasted $80 pair front cover, 2 pieces vapour blasted $60 main seal vapour blasted $40 inlet manifold vapour blasted 2.5 $120 ECUs, 325 pfl 0261 200 073, facelift 0261 200 173 chipped for BTB exhaust, 320 facelift 0261 200 172, AFM for 320i, off SA spec car, 0280 202 093, ran ok $60 collect from south auckland, smaller parts can be delivered by courier. Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted March 9, 2020 sir, do you have M20B25 325 pistons available Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted March 10, 2020 (edited) no pistons separately. There are 6 good ones still inside the short block rotating assembly however. ECU marked Marks red track day is sold. Edited March 10, 2020 by Paragon more info Quote Share this post Link to post Share on other sites
