cat007 0 Report post Posted March 11, 2020 Hi all I have a Jap imoort 2008 323i E90 with the GM trans and I would like to change the fluid. I have read a lot of conflicting advice on what fluid to use, DEX VI, DEX III, even the supercheap site say to use DEX III. Should I bother sourcing a Penrite/Valvoline alternative or should I just buy the stuff from BMW? I was assuming that buying OEM from BMW would be crazy expensive? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 11, 2020 Try Alltranz https://www.alltranz.co.nz/ Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 11, 2020 5 hours ago, B.M.W Ltd said: Try Alltranz https://www.alltranz.co.nz/ Thanks! Gave them a call. Lubegard fluid and filter and pan gasket in stock. Will pick them up and do it this weekend! Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 11, 2020 Next question: I was just going to drain fluid, take pan off, change filter, clean magnets and put pan back on then fill back up. But perhaps I was thinking of doing a proper flush. What's the best process for a full flush? I've been told I could just have the car in drive and engine running, fill through the side fill hole and drain out the bottom until the fluid out the bottom runs clean. I'm not sure how the new fluid wouldn't just drain straight out the bottom though....? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 11, 2020 You will never drain it completely in car. Drain it, refill with new oil, run it for ten minutes, then drain it again before removing the pan. Then replace the filter and refit the pan with new gasket and carry out the refill process.. I would not carry out the above process with the risk of running it dry while doing so. If you want I can PM my contact number 2 Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 11, 2020 Thanks for that. Great advice. I will see how the fluid looks first round and decide then if I do a second change. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 11, 2020 17 minutes ago, cat007 said: I will see how the fluid looks first round and decide then if I do a second change. Make sure it's warm for the first drain and check fluid with a magnet if there is allot of discoloration 1 Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 11, 2020 2 minutes ago, B.M.W Ltd said: Make sure it's warm for the first drain and check fluid with a magnet if there is allot of discoloration Is there a lower and upper limit for this? I know with my Falcon's ZF it has to be around 30C when filling/checking etc. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted March 11, 2020 45C on most Euro transmissions 3 Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 12, 2020 Thanks Quote Share this post Link to post Share on other sites
cat007 0 Report post Posted March 13, 2020 Hoping to change fluid tomorrow. I bought 2x 5.7L LubeGard which is what AllTranz recommend and will do the drain, fill, run for ten minutes, drain, change filter and mechatronics seal/plug. I'm assuming 5.7L is enough to fill? Quote Share this post Link to post Share on other sites
