ilovetennis
Help Needed to Recover an FRM
On 5/7/2020 at 6:59 PM, ilovetennis said:
Hi,
Is there anyone in Auckland that can help me recover an FRM that stopped working after the battery went flat?
What's wrong with the FRM? What model is it in etc. If you cannot "see" the module on the bus at all then it's likely has a corrupted bootloader (or has died in some other physical way), and needs an XProg or something similar to put right.
If it's not  I have a couple of trace files with FRM settings I've loaded from various modules I've come across. I only have E series experience and am currently only setup to reliably diagnose and code (don't have a decent interface or charger for reliable programming). I've had a few FRM issues over the years so know my way around that annoying box.
