bumpstop325 0 Report post Posted April 12, 2006 (edited) PARAMETER................... TO INCREASE UNDERSTEER... ......TO INCREASE OVERSTEER FRONT TIRE PRESSURE .................LOWER................................. HIGHER REAR TIRE PRESSURE ...................HIGHER .................................LOWER FRONT TIRE WIDTH ......................SMALLER ...............................LARGER REAR TIRE WIDTH........................ LARGER ..............................SMALLER FRONT CAMBER .........................MORE POSITIVE ...................MORE NEGATIVE REAR CAMBER ..........................MORE NEGATIVE................. MORE POSITIVE FRONT SPRINGS .............................STIFFER ...............................SOFTER REAR SPRINGS............................... SOFTER .............................STIFFER FRONT ANTI-SWAY BAR................... STIFFER .............................SOFTER REAR ANTI-SWAY BAR..................... SOFTER .............................STIFFER This is a reference guide only. You have warned. Edited April 13, 2006 by Andrew Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted April 12, 2006 Credit to bmwe30.net Quote Share this post Link to post Share on other sites
