Fants 0 Report post Posted June 11, 2020 (edited) Hi all Have been having an issue with my X3 (250000km) having a small fluctuation (Approx 100) in RPM when idling. I did have it diagnosed and the P code was for spark plug and/or ignition coil on number 2 cylinder. I have replaced both and no change. Also been noticing a squeaking whirring sound from the left hand side of the engine (pax side of car) no fault showing on the OBD2. Any ideas. TIA. Edited June 11, 2020 by Fants Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 11, 2020 (edited) P codes won't help. It could be a number of things. You need to get it diagnosed by a BMW specialist or the dealer otherwise you'll end up with empty pockets and getting nowhere. It's more than likely to be air leaks Edited June 11, 2020 by B.M.W Ltd 1 Quote Share this post Link to post Share on other sites
