Fants
X3 2004 E83 RPM fluctuation - Help needed to diagnose
Hi all
Have been having an issue with my X3 (250000km) having a small fluctuation (Approx 100) in RPM when idling.
I did have it diagnosed and the P code was for spark plug and/or ignition coil on number 2 cylinder.
I have replaced both and no change.
Also been noticing a squeaking whirring sound from the left hand side of the engine (pax side of car) no fault showing on the OBD2.
Any ideas.
TIA.
Edited by Fants
P codes won't help. It could be a number of things. You need to get it diagnosed by a BMW specialist or the dealer otherwise you'll end up with empty pockets and getting nowhere. It's more than likely to be air leaks
Edited by B.M.W Ltd
