GUNSMOKEJAE 0 Report post Posted July 27, 2020 I had a battery doing weird things when tested the battery itself not connected to terminals reads 12 to 12.1 volts while connected to terminals reads 11.8 volts now when I try start the car wouldn’t turn over or anything so I tried jump starting via connections in engine bay no success so I jumped from battery directly in the boot the engine would crank but wouldn’t start again and would just wind over and over slowing down the longer I tried to crank it over I then checked the fuses fuel pump relay etc fuses are fine so I replaced the battery with a brand new battery now in the car still only cranks and won’t fully start properly just keeps winding over until I press start/stop button to turn car off ignition phase ????? is this a computer reset issue ? where I have program ECU with key to new battery as it’s (for some reason) not registering that a new battery has been connected ??? Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted July 27, 2020 Hi Jake, welcome to the forum. What year or model is your 320? It will help in fault finding. Do you have a scanner for the car? Knowing if there are any trouble codes helps. Some BMW's need to have the battery registered to the car so the charging is right. It will not stop the starting of the car. Some older BMW's will loose the link (ISN number) between the DME (engine computer) and EWS (security system) when the battery plays up. So, knowing the model/year of your car helps lots. Quote Share this post Link to post Share on other sites
