Contrails
E30 51mm shock mounts
G'day,
I am searching for L&R side 51mm Shock mounts from an ABS model E30.  For some reason my 325i has 45mm, I am guessing one of the previous owners changed to a 45mm.
Cheers.
On 10/30/2020 at 4:37 PM, swapsndeals said:
might be to fit wider wheels on the front.
Pretty much every reference including real OEM says I should have 51mm shocks up front.  So, most likely mine got changed by one of the previous owners.
Yea, I noticed Monroe inserts fit both size struts. If thats what you need I have a new set here
Thanks for the offer but I have some Billy B8 51mm ready to go. Just need the shock mount.
