camman 0 Report post Posted November 30, 2020 dose any one no of a good place to get a remap on a 2006 530d , should i just get the motor done or should i let them change the setting in the auto as well . Quote Share this post Link to post Share on other sites
promo 93 Report post Posted November 30, 2020 (edited) I can help if you require a stage 1 tune. I charge ~$550 and do many automotive places. Can delete the egr at the same time. Edited November 30, 2020 by promo Quote Share this post Link to post Share on other sites
camman 0 Report post Posted November 30, 2020 10 hours ago, promo said: I can help if you require a stage 1 tune. I charge ~$550 and do many automotive places. Can delete the egr at the same time. How dose this work do i remove the ecu and send it to you ? , and is a stage 1 tune pretty stand across the industry. I have block off vacuum line to egr removed manifold cleaned out carbon and remove swirl flaps . Quote Share this post Link to post Share on other sites
promo 93 Report post Posted November 30, 2020 Yes, you can send ecu. e60's they're located on the right side corner under bonnet. Quote Share this post Link to post Share on other sites
camman 0 Report post Posted November 30, 2020 So what is a stage 1 tune is this a industry stand or is it your own stage 1 . What gains ? Quote Share this post Link to post Share on other sites
promo 93 Report post Posted November 30, 2020 generally around ~30hp and ~80nm - Custom tune based on the read of your ECU Quote Share this post Link to post Share on other sites
