Emmajessicafrost 2 Report post Posted December 3, 2020 Hi there, im after the drivers rear trailing arm and half axle for a 1998 wide body Z3 roadster. Any help would be much appreciated. Thank you! 😊 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted December 3, 2020 Hi Jessica You will need to be a bit more specific in your description. There are a few different half shafts that come with the same size trailing arms. Don't want you buying parts that don't fit. Your car is a 1998 wide body Z3 roadster. The wide body came as either a 2.8L or 3.2 Z3m. I'm guessing that your car is the 2.8L. I'm making assumptions already. Suggest that you go to www.RealOEM.com and put the last 7 digits of your VIN number into the search tool. This will let you browse for part numbers specific to your car. In the "rear axle" section, you can find the part number for the trailing arm you need as well as the half shaft. You may need to know if your car is fitted with the "S209A, Differential lock 25%" option, as there may be two different part numbers for the half shaft. If you need this information, do a VIN Decode. Its a paid service now. Once you have the part numbers for the trailing arm and half shaft, you can go shopping, confident that the parts you buy will fit the car. Regards Murray Quote Share this post Link to post Share on other sites
Emmajessicafrost 2 Report post Posted December 7, 2020 Thank you heaps for your help i will try that website..fingers crossed ☺ 1 Quote Share this post Link to post Share on other sites
