gjm 3300 Report post Posted January 2, 2021 The left (rear) reversing bulb on Mrs M's Baur is refusing to light. Swapping the bulb into another position - indicators, same purpose on the opposite side - shows it is fine. The right reversing bulb does light, suggesting it is not a gearbox switch issue. All other bulbs light correctly. So, likely to be a cluster wiring issue. Anyone able to advise how to dismantle the cluster unit? There are retaining clips over a plastic panel, but even once the clips are released the panel will not come apart. I'll check the wiring in the meantime. According to the diagram I have, it's the 'BU/WT' wire that provides the feed to the cluster(s) and a WT (white?) wire that provides power to the bulb(s). Earth is common. Quote Share this post Link to post Share on other sites
