Gilla850r
E60 transmission failure
Hi all, newbie to here😁.
Does anyone out there know if the ZF6HP19 in the E90 ( N46 engine) has the same bell housing pattern as an E60 with an M54 engine.
Just seems E60 Auto transmission are hard to find.
Same ZF6HP19 is in E90,
Thanks for any input
Hey all, just an update for any interested parties.
I emailed ZF in Australia and the told me all 6HP19 internals are the same, EXCEPT if it comes out of a 4WD(AWD). I purchased a ZF6HP19 from an E90 (N46 engine), stripped the internals and put it into my ZF6HP19 case. (E60 with M54 engine). Changed the mechatronics block and pipe seals and reassembled. It went fine, no dramas and very smooth. Happy days. Hope this helps someone.
  • Like 8
  • Thanks 1
Good to know. What fluid did you fill it up with out of interest?
