GDH
1999 E39 540i Fuel Pressure Tester
Hi,
Long time reader, first time poster.
I've been having a few issues with longer than normal cranking times on start-up, and want to check the fuel pump pressure, and fuel pump check valve.
No problem finding a Fuel Pump Tester, but I cannot locate a fitting that will screw on to the Schrader valve on the car's fuel rail.
Can anyone help me locate / buy / hire / borrow! an adapter ?
I've attached a pic of the valve on the fuel rail.
Thanks in advance for any comments / queries.
Edited by GDH
Cheap pressure tester from trademe has a shrader adapter and they're fine for occasional use
Awesome, thanks !  I missed this one in my search, and have had to return it; so will try again.
