kko110 4 Report post Posted May 13, 2021 Has anyone got some Front hubs for a small bearing E21? Thanks Karl Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted May 13, 2021 I've probably got some spares, would need to have a hunt around and they are probably still on the struts. Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted May 13, 2021 That would be great if you could. Thanks. I am after the earlier hubs that had the smaller wheel bearings... Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted May 14, 2021 Also by chance do you have a set of rear drum brakes cw backing plates? Just for reference the front hubs outer bearing should be 17mm ID. Thanks again Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted May 17, 2021 Sorry to hassle you but did you get a chance to have a hunt for the hubs and rear brakes? Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted May 24, 2021 Found a set of front struts / hubs, will have to take them off to measure the bearings, I have got some rear arms with brake plates on them, quite rusty but spare if you need them. Will try to measure tonight. Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted May 24, 2021 Have taken a hub off and measured, id of small bearing is 19mm so probably not what you need. Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted May 24, 2021 thanks heaps for trying anyway. Are the vented discs in good condition? Or are they not the vented type? Thanks Karl Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted May 24, 2021 No, solid discs and quite rusty now. Quote Share this post Link to post Share on other sites
