Craig B 0 Report post Posted August 31, 2021 Hi All As a follow-up to my previous coolant woes, I've added some pictures on how to replace the 'Camshaft Cover Plate" Quick Recap, used a cheap top coolant hose, leaked from day 1 and I put very small crack in radiator plastic header tank, I then used radiator stop leak (DON"T DO THIS....), gummed up thermostat, pressurized coolant system. I finally replaced all hoses, new thermostat, new radiator, still got a small coolant leak, seemed to be coming from behind the engine at the firewall, sealed itself for a while, but I over filled the coolant tank (DON"T DO THIS...), and it started to loose coolant again, also smelt out the car with coolant smell through aircon. Step 1: Found video on youtube by a polish guy who traced his 'back of engine coolant leak" to the camshaft cover, American stuff is no use as they don't seem to have the 2.0L engine Step 2: Order replacement cover from e-bay Step 3: Remove the top cover with aircon filter - 6 screws Step 4: Un-clip and remove small plastic panels on both sides Step 5: Un-clip cross engine cable holder and release cables, unlcip back cable holder from plenum (they un-clip and pull towards the front) Step 6: Undo two screws on plenum panel and lift up and out to release, remove weather sltrip Step 7: Unclip cam cover breather an cable tie out of the way Step 8: Undo hose clip on ali block at back of engine, and undo quick connect on brake aster cylinder - remove whole hose Step 9: Use Torque socket to undo the tower strut Step 10: Unscrew cap and use torque socket to undo bolt, remove brace Step 11: Now that the area is relatively clear, you're going to have to squeeze down behind the engine between the fire-wall with a 10mm ratchet spanner and loosen/remove the 4 bolts holding the camshaft cover in place. NOTE: Make note of orientation before removing You are probably going to need to pry it off with a screw driver. NOTE: You are going to loose a bunch of coolant so be prepared. I tried several times to get a photo, but it's too cramped, I got a clip of the corner... Down here.... It's probably going to look a little like this Step 12: Fit new one, brace yourselves, it can take a while to get the bugger lined up, and all the bolts in holes... Brace yourself for hand cramps Step 13: Reassemble the rest of the car Step 14: Refill coolant (DON"T OVERFILL...) Step 15: Run engine, check for leaks Fingers crossed you'll be coolant leak free, happy days Quote Share this post Link to post Share on other sites
Eagle 1768 Report post Posted September 1, 2021 Nice writeup, but most here are savvy enough not to ever own this engine so you efforts maybe a bit in vain. Be prepare to play a game of wac-a-mole with the numerous other coolant fittings. Luckily you can do repairs as ive seen multiple people sink money into these and end up taking it out on the workshop. 1 Quote Share this post Link to post Share on other sites
Craig B 0 Report post Posted September 1, 2021 Thanks Jared Yes, I agree entirely, I should have held out for the 6 cylinder as I'm am inline 6 kind of guy (HR 186S), but in my defense for the e90 series, MECHANICAL....WATER......PUMP........ Quote Share this post Link to post Share on other sites
